Ana içeriğe geç
BlackMagic Hyperdeck Studio Mini Fan Replacement
Neye ihtiyacın var
Videoya Genel Bakış
    1. BlackMagic Hyperdeck Studio Mini Fan Replacement, Unscrew the Outer Case: adım 1, 1 resimden 1.
      • 4 Screws on each side
      FixBot'a Sor
      Yorum Ekle
    2. BlackMagic Hyperdeck Studio Mini Fan Replacement, Remove Fan: adım 2, 1 resimden 1.
      • 2 - Screws
      • 1 - Pull cable
      FixBot'a Sor
      Yorum Ekle
    3. BlackMagic Hyperdeck Studio Mini Fan Replacement, Cut Off Connector from both the old and new fan: adım 3, 1 resimden 1.
      • Leave some length to solder with and to reach connector on main board.
      FixBot'a Sor
      Yorum Ekle
    4. BlackMagic Hyperdeck Studio Mini Fan Replacement, Prep Fan Wires and Connector Wires: adım 4, 1 resimden 1.
      • Strip Wires, Tin Wires, and prep by adding heat shrink tubing on wires (before shrinking).
      FixBot'a Sor
      Yorum Ekle
    5. BlackMagic Hyperdeck Studio Mini Fan Replacement, Solder Connecter to Fan: adım 5, 3 resimden 1. BlackMagic Hyperdeck Studio Mini Fan Replacement, Solder Connecter to Fan: adım 5, 3 resimden 2. BlackMagic Hyperdeck Studio Mini Fan Replacement, Solder Connecter to Fan: adım 5, 3 resimden 3.
      • Solder the new fan to the old connector using the following pinout.
      • Adjust heat shrink tubing so it covers the solder joints and use heat gun to shrink tubing.
      FixBot'a Sor
      Yorum Ekle
    6. BlackMagic Hyperdeck Studio Mini Fan Replacement, Re-assemble fan to device with fan label facing out: adım 6, 2 resimden 1. BlackMagic Hyperdeck Studio Mini Fan Replacement, Re-assemble fan to device with fan label facing out: adım 6, 2 resimden 2.
      • Re-assemble fan to device with fan label facing out.
      FixBot'a Sor
      Yorum Ekle
      • OPTIONAL - Use Small Round Nose Pliers to break off case grill to make fan even quieter.
      FixBot'a Sor
      Yorum Ekle
    7. BlackMagic Hyperdeck Studio Mini Fan Replacement, Re-Assemble Case: adım 8, 1 resimden 1.
      • Re-Assemble case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Kevin Krautle
562 İtibar
2 adet Kılavuz yazıldı
7Kılavuz Yorumları
THANK YOU SO MUCH!!!! This was the perfect solution. The new Noctua fan even came with solderless connectors. The whole job only took 20 minutes. It is now completely silent!
tberntson - Yanıt Paylaş
Just replaced mine monitoring the temperature now. As @tberntson mentioned, the fan comes with some Skotchlok connectors and no soldering even required. I can’t believe how quiet the new fan is. Complete night and day difference. Kevin, thanks so much for sharing this.
Adrian Cho - Yanıt Paylaş
Hi! any one that have the part number for the Nactua fan with Skotchlok connectors is it NF-A4x20-PWM?
mikaelf - Yanıt Paylaş
The connector you need is a Micro JST ZH 1.5mm 4-pin female connector. You can pick them up pre-wired on eBay.
Jamie - Yanıt Paylaş
Thank you so much! I soldered it and it works great! So silent now that I can´t hear it at all!
pzacharias - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 52
Her zaman: 5,874
