Ana içeriğe geç
Blackberry 7105t Disassembly
Neye ihtiyacın var
  1. Blackberry 7105t Disassembly, Blackberry 7105t Disassembly: adım 1, 1 resimden 1.
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t Disassembly: adım 2, 1 resimden 1.
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t Disassembly: adım 3, 1 resimden 1.
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t Disassembly: adım 4, 1 resimden 1.
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t Disassembly: adım 5, 3 resimden 1. Blackberry 7105t Disassembly: adım 5, 3 resimden 2. Blackberry 7105t Disassembly: adım 5, 3 resimden 3.
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t Disassembly: adım 6, 1 resimden 1.
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t Disassembly: adım 7, 1 resimden 1.
    • The black battery casing and logic board can now be separated for the following steps.
Sonuç
kelogan
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-17, Regan Fall 2009 Cal Poly, Team 9-17, Regan Fall 2009 üyesi
CPSU-REGAN-F09S9G17
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,135
