Giriş
This guide outlines how to replace the keyboard.
Neye ihtiyacın var
With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
Use a plastic opening tool to lift up the two black clips indicated in the picture.
The keyboard will detach once the clips are unfastened.
