Giriş
For removing and replacing the Blackberry 7520 battery, follow this guide.
Aletler
Hiçbir alete gerek yok.
Parçalar
Hiçbir parçaya gerek yok.
Turn the phone upside down. Push down on the black button on the back of the phone to slide the rear panel off.
  • Turn the phone upside down.
  • Push down on the black button on the back of the phone to slide the rear panel off.
  • The battery should be visible now.
Yorum Ekle
Hold the BlackBerry in one hand face-up with the screen facing towards you. Gently smack the phone against your hand to dislodge the battery. Gently smack the phone against your hand to dislodge the battery.
  • Hold the BlackBerry in one hand face-up with the screen facing towards you.
  • Gently smack the phone against your hand to dislodge the battery.
Yorum Ekle
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
To install the battery turn the phone on its back. Line the battery in place where the gold connectors (red circle) line up with the gold pins (blue circle) Once the battery is lined up push the battery in and down until it is locked in.
  • To install the battery turn the phone on its back.
  • Line the battery in place where the gold connectors (red circle) line up with the gold pins (blue circle)
  • Once the battery is lined up push the battery in and down until it is locked in.
Yorum Ekle
Once the battery has been put back in, line the the black button (red circle) of the panel up with its socket (blue circle) in the BlackBerry phone. Push the panel inwards then down until it locks in.
  • Once the battery has been put back in, line the the black button (red circle) of the panel up with its socket (blue circle) in the BlackBerry phone.
  • Push the panel inwards then down until it locks in.
  • Once the panel is in you have successfully changed your battery!
Yorum Ekle
Bitiş Çizgisi
Nathan
31 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-7, Forte Winter 2010 Cal Poly, Team 5-7, Forte Winter 2010 üyesi
CPSU-FORTE-W10S5G7
5 Üye
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Tüm Zamanlar: 1,423
