Ana içeriğe geç
Blackberry 7520 Motherboard Replacement
Neye ihtiyacın var
  1. Blackberry 7520 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Blackberry 7520 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Blackberry 7520 Motherboard Replacement: adım 2, 3 resimden 1. Blackberry 7520 Motherboard Replacement: adım 2, 3 resimden 2. Blackberry 7520 Motherboard Replacement: adım 2, 3 resimden 3.
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Blackberry 7520 Motherboard Replacement, Motherboard: adım 3, 2 resimden 1. Blackberry 7520 Motherboard Replacement, Motherboard: adım 3, 2 resimden 2.
    • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
  4. Blackberry 7520 Motherboard Replacement: adım 4, 2 resimden 1. Blackberry 7520 Motherboard Replacement: adım 4, 2 resimden 2.
    • Use a pick or plastic opening tool to push the clips holding the rear away from you.
    • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
  5. Blackberry 7520 Motherboard Replacement: adım 5, 1 resimden 1.
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  6. Blackberry 7520 Motherboard Replacement: adım 6, 2 resimden 1. Blackberry 7520 Motherboard Replacement: adım 6, 2 resimden 2.
    • Slide the rear panel forward to reveal the motherboard.
  7. Blackberry 7520 Motherboard Replacement: adım 7, 2 resimden 1. Blackberry 7520 Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the indicated screws using a T6 Torx screwdriver.
  8. Blackberry 7520 Motherboard Replacement: adım 8, 2 resimden 1. Blackberry 7520 Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the motherboard.
    • Remove the indicated screw using the T6 Torx screwdriver.
  9. Blackberry 7520 Motherboard Replacement: adım 9, 2 resimden 1. Blackberry 7520 Motherboard Replacement: adım 9, 2 resimden 2.
    • Pull the metal plate away from the front panel of the cell phone.
  10. Blackberry 7520 Motherboard Replacement: adım 10, 1 resimden 1.
    • Place the faceplate face-down and the interior of the phone face-up, as shown.
Sonuç
Nathan
31 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-7, Forte Winter 2010 Cal Poly, Team 5-7, Forte Winter 2010 üyesi
CPSU-FORTE-W10S5G7
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 3,583
