Ana içeriğe geç
Blackberry 7520 Speaker Replacement
Neye ihtiyacın var
  1. Blackberry 7520 Speaker Replacement, Battery: adım 1, 2 resimden 1. Blackberry 7520 Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Blackberry 7520 Speaker Replacement: adım 2, 3 resimden 1. Blackberry 7520 Speaker Replacement: adım 2, 3 resimden 2. Blackberry 7520 Speaker Replacement: adım 2, 3 resimden 3.
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Blackberry 7520 Speaker Replacement, Speaker: adım 3, 2 resimden 1. Blackberry 7520 Speaker Replacement, Speaker: adım 3, 2 resimden 2.
    • Use a T6 Torx screwdriver to remove the six screws located on the rear of the phone.
  4. Blackberry 7520 Speaker Replacement: adım 4, 2 resimden 1. Blackberry 7520 Speaker Replacement: adım 4, 2 resimden 2.
    • Use a pick or plastic iPod opening tool to push the clips, that are holding the rear casing. Apply a firm pressure at a forty-five degree angle to dislodge the clips.
    • Applying too much pressure could break the plastic clips and permanently damage the casing, so be careful.
  5. Blackberry 7520 Speaker Replacement: adım 5, 1 resimden 1.
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  6. Blackberry 7520 Speaker Replacement: adım 6, 1 resimden 1.
    • Do not try to pull the two pieces apart. You may tear the antenna cable. Instead, fold the two pieces open to avoid stress on the cable.
  7. Blackberry 7520 Speaker Replacement: adım 7, 1 resimden 1.
    • Separating the two halves allows you to access the speaker. Which is located in the front half of the case.
  8. Blackberry 7520 Speaker Replacement: adım 8, 3 resimden 1. Blackberry 7520 Speaker Replacement: adım 8, 3 resimden 2. Blackberry 7520 Speaker Replacement: adım 8, 3 resimden 3.
    • Insert a plastic opening tool between the speaker and the case. Then pry the speaker out.
    • To reinsert the speaker, align the blue notch to the blue stud. Then the red notch to the red stud. As shown in the last picture.
Sonuç
Nathan
31 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-7, Forte Winter 2010 Cal Poly, Team 5-7, Forte Winter 2010 üyesi
CPSU-FORTE-W10S5G7
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 2,457
