Ana içeriğe geç
Blackberry 8700c Battery Replacement
  1. Blackberry 8700c Battery Replacement, Battery: adım 1, 3 resimden 1. Blackberry 8700c Battery Replacement, Battery: adım 1, 3 resimden 2. Blackberry 8700c Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the back cover by pushing the button near the bottom of the phone and sliding the cover off.
  2. Blackberry 8700c Battery Replacement: adım 2, 2 resimden 1. Blackberry 8700c Battery Replacement: adım 2, 2 resimden 2.
    • Using your fingernail, remove the battery by pulling on the notch on the top-right of the battery.
    • If you are not installing a new battery, move on to the next step. If you are installing a new battery, read on.
    • Install the new battery by first placing the bottom end of the battery in the phone and then pushing the battery into place.
Sonuç
To reassemble your Blackberry 8700c, follow these instructions in reverse order.
k3nt
42 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-4, Maness Fall 2009 Cal Poly, Team 18-4, Maness Fall 2009 üyesi
CPSU-MANESS-F09S18G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 2,836
