Ana içeriğe geç
Blackberry Bold 9000 LCD Screen Replacement
Neye ihtiyacın var
  1. Blackberry Bold 9000 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 LCD Screen Replacement: adım 3, 1 resimden 1.
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 LCD Screen Replacement, Rear Case: adım 4, 1 resimden 1.
    • Remove the SIM card.
  5. Blackberry Bold 9000 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 LCD Screen Replacement, LCD Screen: adım 7, 1 resimden 1.
    • With the same plastic opening tool, lift the motherboard up and out.
    • Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
  8. Blackberry Bold 9000 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Using a spudger, lift the ribbon band in the upper right-hand corner up and away from the motherboard assembly until it disconnects.
  9. Blackberry Bold 9000 LCD Screen Replacement: adım 9, 1 resimden 1.
    • Turn the motherboard assembly over.
    • Starting at the lower corners of the screen, begin to lift the screen away from the motherboard using the spudger.
    • Do this step very slowly to avoid breaking the screen or the motherboard. The backing will eventually separate.
    • Remove the plastic bit that hides the speaker grill - it is stuck with double-sided tape.
    • With a thin blade/pin, ease the speaker grill and the metal plate away from the old lcd screen.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Kelly
566 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-17, Maness Winter 2012 Cal Poly, Team 8-17, Maness Winter 2012 üyesi
CPSU-MANESS-W12S8G17
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 7,543
