Ana içeriğe geç
Blackberry Bold 9000 Volume Toggle Replacement
Neye ihtiyacın var
  1. Blackberry Bold 9000 Volume Toggle Replacement, Battery: adım 1, 1 resimden 1.
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Volume Toggle Replacement: adım 2, 1 resimden 1.
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Volume Toggle Replacement: adım 3, 1 resimden 1.
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Volume Toggle Replacement, Rear Case: adım 4, 1 resimden 1.
    • Remove the SIM card.
  5. Blackberry Bold 9000 Volume Toggle Replacement: adım 5, 1 resimden 1.
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Volume Toggle Replacement: adım 6, 1 resimden 1.
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Volume Toggle Replacement, Volume Toggle: adım 7, 1 resimden 1.
    • Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Try to remove from left to right, using caution with the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Volume Toggle Replacement: adım 8, 1 resimden 1.
    • Locate the volume toggle on the main frame of the phone.
    • Using the spudger, push the toggle in from the outside and remove.
  9. Blackberry Bold 9000 Volume Toggle Replacement: adım 9, 1 resimden 1.
    • Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Make sure the toggle is completely in place by pressing it outward into the frame.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kelly
566 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-17, Maness Winter 2012 Cal Poly, Team 8-17, Maness Winter 2012 üyesi
CPSU-MANESS-W12S8G17
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 2,471
