Ana içeriğe geç
Blackberry Bold 9650 Mother Board Replacement
Neye ihtiyacın var
  1. Blackberry Bold 9650 Mother Board Replacement, Battery: adım 1, 2 resimden 1. Blackberry Bold 9650 Mother Board Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Mother Board Replacement: adım 2, 1 resimden 1.
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Mother Board Replacement, SIM Card: adım 3, 1 resimden 1.
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Mother Board Replacement: adım 4, 1 resimden 1.
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Mother Board Replacement, Back Chassis: adım 5, 1 resimden 1.
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Mother Board Replacement: adım 6, 1 resimden 1.
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Mother Board Replacement: adım 7, 1 resimden 1.
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Mother Board Replacement: adım 8, 1 resimden 1.
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Blackberry Bold 9650 Mother Board Replacement, Mother Board: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
  10. Blackberry Bold 9650 Mother Board Replacement: adım 10, 1 resimden 1.
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
  11. Blackberry Bold 9650 Mother Board Replacement: adım 11, 1 resimden 1.
    • Using a pair of tweezers, remove the three ribbon connectors.
  12. Blackberry Bold 9650 Mother Board Replacement: adım 12, 1 resimden 1.
    • Remove the mother board by lifting the board upward.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan
696 İtibar
11 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-5, Benson Spring 2012 Clemson, Team 2-5, Benson Spring 2012 üyesi
CLEM-BENSON-S12S2G5
2 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 3,846
