Ana içeriğe geç
Blackberry Bold 9900 Back Case Replacement
Neye ihtiyacın var
    1. Blackberry Bold 9900 Back Case Replacement, Battery: adım 1, 1 resimden 1.
      • Place phone screen down.
      • Use your finger to life upward on the battery case.
      • Pull the cover away from the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Blackberry Bold 9900 Back Case Replacement: adım 2, 1 resimden 1.
      • Lift the edge of battery with the green stripe upward to remove battery.
      FixBot'a Sor
      Yorum Ekle
    1. Blackberry Bold 9900 Back Case Replacement, Mini-SIM removal: adım 3, 1 resimden 1.
      • The Mini-SIM card is located inside the red rectangle.
      • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
      FixBot'a Sor
      Yorum Ekle
    1. Blackberry Bold 9900 Back Case Replacement, MicroSD card: adım 4, 2 resimden 1. Blackberry Bold 9900 Back Case Replacement, MicroSD card: adım 4, 2 resimden 2.
      • The MicroSD card is located where the red rectangle is shown.
      • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
      FixBot'a Sor
      Yorum Ekle
    1. Blackberry Bold 9900 Back Case Replacement, Keyboard: adım 5, 2 resimden 1. Blackberry Bold 9900 Back Case Replacement, Keyboard: adım 5, 2 resimden 2.
      • Lift the bezel at the bottom of the phone up and peel it away from the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Blackberry Bold 9900 Back Case Replacement: adım 6, 2 resimden 1. Blackberry Bold 9900 Back Case Replacement: adım 6, 2 resimden 2.
      • Remove the two exposed screws using the T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Blackberry Bold 9900 Back Case Replacement: adım 7, 1 resimden 1.
      • Now lever the keyboard up using the screwdriver in the indicated hole.
      FixBot'a Sor
      Yorum Ekle
    4. Blackberry Bold 9900 Back Case Replacement: adım 8, 2 resimden 1. Blackberry Bold 9900 Back Case Replacement: adım 8, 2 resimden 2.
      • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
      FixBot'a Sor
      Yorum Ekle
    1. Blackberry Bold 9900 Back Case Replacement, Back Case: adım 9, 1 resimden 1.
      • Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
      FixBot'a Sor
      Yorum Ekle
    2. Blackberry Bold 9900 Back Case Replacement: adım 10, 1 resimden 1.
      • Now, carefully and gently using your fingers, lift and remove the assembly from the back case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Sowmika
256 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G4, Johnson Spring 2018 Baylor, Team S1-G4, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S1G4
3 Üyeler
66 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 75
Her zaman: 2,268
