Ana içeriğe geç
Blackberry Bold 9900 Back Case Replacement
Neye ihtiyacın var
  1. Blackberry Bold 9900 Back Case Replacement, Battery: adım 1, 1 resimden 1.
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Back Case Replacement: adım 2, 1 resimden 1.
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Back Case Replacement, Mini-SIM removal: adım 3, 1 resimden 1.
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
  4. Blackberry Bold 9900 Back Case Replacement, MicroSD card: adım 4, 2 resimden 1. Blackberry Bold 9900 Back Case Replacement, MicroSD card: adım 4, 2 resimden 2.
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  5. Blackberry Bold 9900 Back Case Replacement, Keyboard: adım 5, 2 resimden 1. Blackberry Bold 9900 Back Case Replacement, Keyboard: adım 5, 2 resimden 2.
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  6. Blackberry Bold 9900 Back Case Replacement: adım 6, 2 resimden 1. Blackberry Bold 9900 Back Case Replacement: adım 6, 2 resimden 2.
    • Remove the two exposed screws using the T5 Torx screwdriver.
  7. Blackberry Bold 9900 Back Case Replacement: adım 7, 1 resimden 1.
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  8. Blackberry Bold 9900 Back Case Replacement: adım 8, 2 resimden 1. Blackberry Bold 9900 Back Case Replacement: adım 8, 2 resimden 2.
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
  9. Blackberry Bold 9900 Back Case Replacement, Back Case: adım 9, 1 resimden 1.
    • Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
  10. Blackberry Bold 9900 Back Case Replacement: adım 10, 1 resimden 1.
    • Now, carefully and gently using your fingers, lift and remove the assembly from the back case.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Sowmika
253 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G4, Johnson Spring 2018 Baylor, Team S1-G4, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 1,441
