Ana içeriğe geç
Blackberry Bold 9900 Keyboard Replacement
Neye ihtiyacın var
  1. Blackberry Bold 9900 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Keyboard Replacement: adım 2, 1 resimden 1.
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Keyboard Replacement, MicroSD card: adım 3, 2 resimden 1. Blackberry Bold 9900 Keyboard Replacement, MicroSD card: adım 3, 2 resimden 2.
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  4. Blackberry Bold 9900 Keyboard Replacement, Keyboard: adım 4, 2 resimden 1. Blackberry Bold 9900 Keyboard Replacement, Keyboard: adım 4, 2 resimden 2.
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  5. Blackberry Bold 9900 Keyboard Replacement: adım 5, 2 resimden 1. Blackberry Bold 9900 Keyboard Replacement: adım 5, 2 resimden 2.
    • Remove the two exposed screws using the T5 Torx screwdriver.
  6. Blackberry Bold 9900 Keyboard Replacement: adım 6, 1 resimden 1.
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  7. Blackberry Bold 9900 Keyboard Replacement: adım 7, 2 resimden 1. Blackberry Bold 9900 Keyboard Replacement: adım 7, 2 resimden 2.
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris Velasquez
214 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G4, Johnson Spring 2018 Baylor, Team S1-G4, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,554
