Ana içeriğe geç
Blackberry Curve 8320 Front Panel Replacement
Neye ihtiyacın var
  1. Blackberry Curve 8320 Front Panel Replacement, Battery: adım 1, 2 resimden 1. Blackberry Curve 8320 Front Panel Replacement, Battery: adım 1, 2 resimden 2.
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Blackberry Curve 8320 Front Panel Replacement: adım 2, 1 resimden 1.
    • Pull up on the top edge of the battery to remove it.
  3. Blackberry Curve 8320 Front Panel Replacement, Front Panel: adım 3, 3 resimden 1. Blackberry Curve 8320 Front Panel Replacement, Front Panel: adım 3, 3 resimden 2. Blackberry Curve 8320 Front Panel Replacement, Front Panel: adım 3, 3 resimden 3.
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Blackberry Curve 8320 Front Panel Replacement: adım 4, 2 resimden 1. Blackberry Curve 8320 Front Panel Replacement: adım 4, 2 resimden 2.
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Blackberry Curve 8320 Front Panel Replacement: adım 5, 2 resimden 1. Blackberry Curve 8320 Front Panel Replacement: adım 5, 2 resimden 2.
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Blackberry Curve 8320 Front Panel Replacement: adım 6, 1 resimden 1.
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Blackberry Curve 8320 Front Panel Replacement: adım 7, 1 resimden 1.
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Aiello
89 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-6, Regan Fall 2011 Cal Poly, Team 3-6, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G6
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 2,712
