Ana içeriğe geç
Blackberry Curve 8320 LCD Screen Replacement
Neye ihtiyacın var
  1. Blackberry Curve 8320 LCD Screen Replacement, Battery: adım 1, 2 resimden 1. Blackberry Curve 8320 LCD Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Blackberry Curve 8320 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Pull up on the top edge of the battery to remove it.
  3. Blackberry Curve 8320 LCD Screen Replacement, Front Panel: adım 3, 3 resimden 1. Blackberry Curve 8320 LCD Screen Replacement, Front Panel: adım 3, 3 resimden 2. Blackberry Curve 8320 LCD Screen Replacement, Front Panel: adım 3, 3 resimden 3.
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Blackberry Curve 8320 LCD Screen Replacement: adım 4, 2 resimden 1. Blackberry Curve 8320 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Blackberry Curve 8320 LCD Screen Replacement: adım 5, 2 resimden 1. Blackberry Curve 8320 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Blackberry Curve 8320 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Blackberry Curve 8320 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  8. Blackberry Curve 8320 LCD Screen Replacement, LCD Screen: adım 8, 3 resimden 1. Blackberry Curve 8320 LCD Screen Replacement, LCD Screen: adım 8, 3 resimden 2. Blackberry Curve 8320 LCD Screen Replacement, LCD Screen: adım 8, 3 resimden 3.
    • Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
    • The screws are 6mm long.
  9. Blackberry Curve 8320 LCD Screen Replacement: adım 9, 2 resimden 1. Blackberry Curve 8320 LCD Screen Replacement: adım 9, 2 resimden 2.
    • After the bottom two screws have been removed the side casings can be removed.
  10. Blackberry Curve 8320 LCD Screen Replacement: adım 10, 3 resimden 1. Blackberry Curve 8320 LCD Screen Replacement: adım 10, 3 resimden 2. Blackberry Curve 8320 LCD Screen Replacement: adım 10, 3 resimden 3.
    • When all four screws are removed, the keyboard frame, screen housing, screen, and back casing can be separated.
    • The screen frame hooks on to the top of the motherboard with a small tab on the motherboard.
  11. Blackberry Curve 8320 LCD Screen Replacement: adım 11, 1 resimden 1.
    • Place the motherboard on a flat surface with the LCD screen face up.
  12. Blackberry Curve 8320 LCD Screen Replacement: adım 12, 3 resimden 1. Blackberry Curve 8320 LCD Screen Replacement: adım 12, 3 resimden 2. Blackberry Curve 8320 LCD Screen Replacement: adım 12, 3 resimden 3.
    • Using a plastic opening tool, gently pull the connector directly up from the motherboard.
    • Remove the LCD screen from the motherboard.
    • The screen is attached to the motherboard with adhesive.
Sonuç
Christopher Aiello
89 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-6, Regan Fall 2011 Cal Poly, Team 3-6, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G6
5 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 2,434
