Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Hold the phone with the back facing you.
Press the silver tab down and remove the cover.
Use a plastic opening tool to gently pry the bottom cover loose.
Pull the cover from the front of the phone after the back is loose.
Gently pry off the side casings from the top.
You will not need to remove the sides on the bottom.
Use a plastic opening tool to detach the securing clips holding the the front panel in place.
Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
After the bottom two screws have been removed the side casings can be removed.
When all four screws are removed, the keyboard frame, screen housing, screen, and back casing can be separated.
Using a plastic opening tool, gently pull the connector directly up from the motherboard.
Remove the LCD screen from the motherboard.
