Ana içeriğe geç
Blackberry Curve 8320 Speaker Replacement
Neye ihtiyacın var
  1. Blackberry Curve 8320 Speaker Replacement, Battery: adım 1, 2 resimden 1. Blackberry Curve 8320 Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Blackberry Curve 8320 Speaker Replacement: adım 2, 1 resimden 1.
    • Pull up on the top edge of the battery to remove it.
  3. Blackberry Curve 8320 Speaker Replacement, Front Panel: adım 3, 3 resimden 1. Blackberry Curve 8320 Speaker Replacement, Front Panel: adım 3, 3 resimden 2. Blackberry Curve 8320 Speaker Replacement, Front Panel: adım 3, 3 resimden 3.
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Blackberry Curve 8320 Speaker Replacement: adım 4, 2 resimden 1. Blackberry Curve 8320 Speaker Replacement: adım 4, 2 resimden 2.
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Blackberry Curve 8320 Speaker Replacement: adım 5, 2 resimden 1. Blackberry Curve 8320 Speaker Replacement: adım 5, 2 resimden 2.
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Blackberry Curve 8320 Speaker Replacement: adım 6, 1 resimden 1.
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Blackberry Curve 8320 Speaker Replacement: adım 7, 1 resimden 1.
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  8. Blackberry Curve 8320 Speaker Replacement, Speaker: adım 8, 3 resimden 1. Blackberry Curve 8320 Speaker Replacement, Speaker: adım 8, 3 resimden 2. Blackberry Curve 8320 Speaker Replacement, Speaker: adım 8, 3 resimden 3.
    • Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
    • The screws are 6mm long.
  9. Blackberry Curve 8320 Speaker Replacement: adım 9, 2 resimden 1. Blackberry Curve 8320 Speaker Replacement: adım 9, 2 resimden 2.
    • After the bottom two screws have been removed the side casings can be removed.
  10. Blackberry Curve 8320 Speaker Replacement: adım 10, 3 resimden 1. Blackberry Curve 8320 Speaker Replacement: adım 10, 3 resimden 2. Blackberry Curve 8320 Speaker Replacement: adım 10, 3 resimden 3.
    • Remove the back case.
    • The speaker is located on the back case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Aiello
89 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-6, Regan Fall 2011 Cal Poly, Team 3-6, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G6
5 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 2,029
