Ana içeriğe geç
Blackberry Curve 9300 Keyboard Replacement
Neye ihtiyacın var
  1. Blackberry Curve 9300 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Keyboard Replacement: adım 2, 1 resimden 1.
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Keyboard Replacement: adım 3, 1 resimden 1.
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Keyboard Replacement: adım 5, 2 resimden 1. Blackberry Curve 9300 Keyboard Replacement: adım 5, 2 resimden 2.
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Keyboard Replacement: adım 6, 1 resimden 1.
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Keyboard Replacement: adım 7, 1 resimden 1.
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Keyboard Replacement: adım 8, 1 resimden 1.
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Keyboard Replacement: adım 9, 1 resimden 1.
    • Lift and remove the keyboard.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Rory Stothers
545 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-7, Forte Fall 2013 Cal Poly, Team 14-7, Forte Fall 2013 üyesi
CPSU-FORTE-F13S14G7
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 4,673
