Ana içeriğe geç
Blackberry Curve 9300 Screen Replacement
Neye ihtiyacın var
  1. Blackberry Curve 9300 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Screen Replacement: adım 2, 1 resimden 1.
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Screen Replacement: adım 3, 1 resimden 1.
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Screen Replacement, Keyboard: adım 4, 1 resimden 1.
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Screen Replacement: adım 5, 2 resimden 1. Blackberry Curve 9300 Screen Replacement: adım 5, 2 resimden 2.
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Screen Replacement: adım 6, 1 resimden 1.
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Screen Replacement: adım 7, 1 resimden 1.
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Screen Replacement: adım 8, 1 resimden 1.
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Screen Replacement: adım 9, 1 resimden 1.
    • Lift and remove the keyboard.
  10. Blackberry Curve 9300 Screen Replacement, Screen: adım 10, 1 resimden 1.
    • Locate and remove the two 5mm screws on top of keyboard base using the T6 Torx screwdriver
  11. Blackberry Curve 9300 Screen Replacement: adım 11, 1 resimden 1.
    • Carefully pull the keyboard base up and away from the phone.
    • Disconnect the keyboard base from the phone completely.
  12. Blackberry Curve 9300 Screen Replacement: adım 12, 3 resimden 1. Blackberry Curve 9300 Screen Replacement: adım 12, 3 resimden 2. Blackberry Curve 9300 Screen Replacement: adım 12, 3 resimden 3.
    • Locate and remove the four 5mm screws on the top and bottom of the phone with a T6 Torx screwdriver
  13. Blackberry Curve 9300 Screen Replacement: adım 13, 2 resimden 1. Blackberry Curve 9300 Screen Replacement: adım 13, 2 resimden 2.
    • Use a plastic opening tool to find the crease below the screen.
    • Insert where shown and use the tool to unclip the two sides of screen from body.
    • The opening tool goes approximately midway between the top and bottom edge of the screen.
  14. Blackberry Curve 9300 Screen Replacement: adım 14, 2 resimden 1. Blackberry Curve 9300 Screen Replacement: adım 14, 2 resimden 2.
    • From the back of the phone, use a finger to push the front piece of the phone away from the back piece.
  15. Blackberry Curve 9300 Screen Replacement: adım 15, 3 resimden 1. Blackberry Curve 9300 Screen Replacement: adım 15, 3 resimden 2. Blackberry Curve 9300 Screen Replacement: adım 15, 3 resimden 3.
    • Use a plastic opening tool to detach the ribbon cable from the top left corner of the screen, and separate the screen from the motherboard.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Alek Squires
431 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-7, Forte Fall 2013 Cal Poly, Team 14-7, Forte Fall 2013 üyesi
CPSU-FORTE-F13S14G7
5 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
would appreciate new ldc part # and order info! - - !
Donald Burgo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 4,719
