Ana içeriğe geç
Blackberry Curve 9300 Speaker Replacement
Neye ihtiyacın var
  1. Blackberry Curve 9300 Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Speaker Replacement: adım 2, 1 resimden 1.
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Speaker Replacement: adım 3, 1 resimden 1.
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Speaker Replacement, Keyboard: adım 4, 1 resimden 1.
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Speaker Replacement: adım 5, 2 resimden 1. Blackberry Curve 9300 Speaker Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Speaker Replacement: adım 6, 1 resimden 1.
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Speaker Replacement: adım 7, 1 resimden 1.
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Speaker Replacement: adım 8, 1 resimden 1.
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Speaker Replacement: adım 9, 1 resimden 1.
    • Lift and remove the keyboard.
  10. Blackberry Curve 9300 Speaker Replacement, Speaker: adım 10, 1 resimden 1.
    • Locate and remove the two 5mm screws on top of the keyboard base with a T6 Torx screwdriver.
  11. Blackberry Curve 9300 Speaker Replacement: adım 11, 1 resimden 1.
    • Carefully pull keyboard base up and away from phone.
    • Disconnect keyboard base from phone completely.
  12. Blackberry Curve 9300 Speaker Replacement: adım 12, 3 resimden 1. Blackberry Curve 9300 Speaker Replacement: adım 12, 3 resimden 2. Blackberry Curve 9300 Speaker Replacement: adım 12, 3 resimden 3.
    • Remove the four 5mm screws on the top and bottom of phone with a T6 Torx screwdriver
  13. Blackberry Curve 9300 Speaker Replacement: adım 13, 2 resimden 1. Blackberry Curve 9300 Speaker Replacement: adım 13, 2 resimden 2.
    • Using a prying tool, find the crease below the screen.
    • Insert where shown and use the tool to unclip the two sides of screen from body.
    • Prying tool goes approximately midway between the top and bottom edge of the screen.
  14. Blackberry Curve 9300 Speaker Replacement: adım 14, 2 resimden 1. Blackberry Curve 9300 Speaker Replacement: adım 14, 2 resimden 2.
    • From the back of the phone, use your finger to push the front piece of the phone away from the back piece.
  15. Blackberry Curve 9300 Speaker Replacement: adım 15, 1 resimden 1.
    Satın Al
    • Insert tweezers into the small holes on the top of the speaker.
  16. Blackberry Curve 9300 Speaker Replacement: adım 16, 2 resimden 1. Blackberry Curve 9300 Speaker Replacement: adım 16, 2 resimden 2.
    • Lift the speaker up to remove the speaker from phone.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Alek Squires
431 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-7, Forte Fall 2013 Cal Poly, Team 14-7, Forte Fall 2013 üyesi
CPSU-FORTE-F13S14G7
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 4,161
