Ana içeriğe geç
Blackberry RIM 7250 Side Button Replacement
Neye ihtiyacın var
  1. Blackberry RIM 7250 Side Button Replacement, Battery: adım 1, 3 resimden 1. Blackberry RIM 7250 Side Button Replacement, Battery: adım 1, 3 resimden 2. Blackberry RIM 7250 Side Button Replacement, Battery: adım 1, 3 resimden 3.
    • Push the release button down and away from the device.
    • Slide the cover off toward the bottom of the device, revealing the battery compartment.
  2. Blackberry RIM 7250 Side Button Replacement: adım 2, 3 resimden 1. Blackberry RIM 7250 Side Button Replacement: adım 2, 3 resimden 2. Blackberry RIM 7250 Side Button Replacement: adım 2, 3 resimden 3.
    • Place your finger in the groove next to the battery.
    • Lift your finger up to eject the battery from the battery compartment.
  3. Blackberry RIM 7250 Side Button Replacement: adım 3, 3 resimden 1. Blackberry RIM 7250 Side Button Replacement: adım 3, 3 resimden 2. Blackberry RIM 7250 Side Button Replacement: adım 3, 3 resimden 3.
    • Remove the battery from the compartment.
  4. Blackberry RIM 7250 Side Button Replacement, Back Housing: adım 4, 2 resimden 1. Blackberry RIM 7250 Side Button Replacement, Back Housing: adım 4, 2 resimden 2.
    • Remove the four 10.7 mm Torx T6 screws.
  5. Blackberry RIM 7250 Side Button Replacement: adım 5, 2 resimden 1. Blackberry RIM 7250 Side Button Replacement: adım 5, 2 resimden 2.
    • Remove the two 5 mm Torx T6 screws.
  6. Blackberry RIM 7250 Side Button Replacement: adım 6, 1 resimden 1.
    • Hold the phone with one hand, with the bottom facing toward you.
    • For both clips, insert the plastic opening tool and push away from you.
    • You will hear a clicking sound for each clip that is released.
  7. Blackberry RIM 7250 Side Button Replacement: adım 7, 3 resimden 1. Blackberry RIM 7250 Side Button Replacement: adım 7, 3 resimden 2. Blackberry RIM 7250 Side Button Replacement: adım 7, 3 resimden 3.
    • Grab the back housing from the bottom and lift the housing away from you.
  8. Blackberry RIM 7250 Side Button Replacement, Front Housing: adım 8, 2 resimden 1. Blackberry RIM 7250 Side Button Replacement, Front Housing: adım 8, 2 resimden 2.
    • Place your thumb on the bottom rectangle and your index finger on the top rectangle.
    • Squeeze your fingers together to release the internals from the front housing.
  9. Blackberry RIM 7250 Side Button Replacement: adım 9, 3 resimden 1. Blackberry RIM 7250 Side Button Replacement: adım 9, 3 resimden 2. Blackberry RIM 7250 Side Button Replacement: adım 9, 3 resimden 3.
    • Pull the two pieces apart to separate the front housing from the internals.
  10. Blackberry RIM 7250 Side Button Replacement, Side Button: adım 10, 2 resimden 1. Blackberry RIM 7250 Side Button Replacement, Side Button: adım 10, 2 resimden 2.
    • Remove the single 5 mm Torx T6 screw.
  11. Blackberry RIM 7250 Side Button Replacement: adım 11, 3 resimden 1. Blackberry RIM 7250 Side Button Replacement: adım 11, 3 resimden 2. Blackberry RIM 7250 Side Button Replacement: adım 11, 3 resimden 3.
    • Grab side button housing with your thumb and index finger.
    • Remove the side button housing from the internals.
  12. Blackberry RIM 7250 Side Button Replacement: adım 12, 3 resimden 1. Blackberry RIM 7250 Side Button Replacement: adım 12, 3 resimden 2. Blackberry RIM 7250 Side Button Replacement: adım 12, 3 resimden 3.
    • Hold the side button housing with one hand and hold the side button with the other.
    • Lift the side button from side button housing.
    • There will be a subtle click when the side button is detached from the side button housing.
Sonuç
Noah Eckert
519 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G4, Baechle Fall 2018 IUPUI, Team S2-G4, Baechle Fall 2018 üyesi
IUPUI-BAECHLE-F18S2G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 128
