Giriş
With this replacement guide, you will learn step-by-step how to replace the back speaker.
Parçalar
Hiçbir parçaya gerek yok.
First locate the two switches located on the lower backside of the phone.
Simultaneously, push the two switches forward causing the back to "pop" off.
The back cover should be fully detached from the phone.
Once the battery has been removed, locate the SIM card. The SIM card is typically located in the center of the phone, secured by a metal tray.
Gently force the spudger tool underneath the plastic flap that protects the camera lens.
With the spudger tool underneath the flap, remove the plastic cover by lifting it away from the phone.
