Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
With this replacement guide, you will learn step-by-step how to replace the back speaker.
Neye ihtiyacın var
Locate the two switches toward the bottom corners of the device's back cover.
Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
Locate the SIM card once the battery has been removed. The SIM card is typically located in the center of the phone, and it is secured by a metal tray.
Gently force the spudger tool underneath the plastic flap that protects the camera lens.
With the spudger tool underneath the flap, remove the plastic cover by lifting it away from the phone.
