Ana içeriğe geç
Blackberry Storm 9530 Battery Replacement
Neye ihtiyacın var
  1. Blackberry Storm 9530 Battery Replacement, Back Cover Removal: adım 1, 3 resimden 1. Blackberry Storm 9530 Battery Replacement, Back Cover Removal: adım 1, 3 resimden 2. Blackberry Storm 9530 Battery Replacement, Back Cover Removal: adım 1, 3 resimden 3.
    • Locate the two switches toward the bottom corners of the device's back cover.
    • Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
    • Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
  2. Blackberry Storm 9530 Battery Replacement: adım 2, 1 resimden 1.
    • Identify that the battery is visible once the back cover has been removed, and locate the battery in the rectangular-shaped top half of the device.
    • Pry apart the battery and back of the device using the flat end of your spudger tool or using your finger if you do not have a spudger.
    • Your battery has a specific orientation resembling a horizontal rectangle. Make sure the gold colored leads are aligned with the gold colored strips on your battery before reassembling.
Sonuç
melanie lim
607 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-16, Regan Spring 2014 Cal Poly, Team 9-16, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G16
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 19
Her zaman: 1,761
