Giriş
With a Blackberry Storm 9530, you should be able to benefit from a high quality and responsive LCD/touchscreen. This guide will help utilize your handy skills and aid in removing and/or replacing your device's LCD/Touchscreen.
A functional touchscreen is meant to allow you to control interactions on your device with the touch of a finger. Due to the sensitivity of a touchscreen, though, it may shatter or crack, and this situation may seem like the end of your device’s lifespan. However, underneath the touchscreen is the LCD screen, and this component (along with the touchscreen) can be replaced through the disassembly of your device.
Instead of living with a valuable item that has a shattered touchscreen, you should be able to regain the full potential of your device.
Make sure not to touch any shattered glass/shards of glass with your bare hands.
Use this guide to replace a broken touchscreen or LCD in your Blackberry Storm 9530 phone.
Neye ihtiyacın var
Locate the two switches toward the bottom corners of the device's back cover.
Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
Locate the SIM card once the battery has been removed. The SIM card is typically located in the center of the phone, and it is secured by a metal tray.
Place the opening tool underneath the camera lens' protective plastic cover and pry them apart with gentle force.
Make sure the plastic cover has been fully removed by carefully lifting it away from the device with your fingers.
Flip the device so that the touchscreen and Blackberry logo is facing you.
Place the opening tool underneath the front plastic cover located below the buttons with red and green phone symbols.
Lift and remove the plastic cover once the opening tool is in place. Make sure the plastic cover can be fully detached from the rest of the device.
Locate the red tabbed pin strip connected to the motherboard. The red tabbed pin strip is located on the right-hand side of the back of the phone.
Disconnect the red tabbed pin strip from the motherboard by inserting the opening tool under the side of the tab and gently pulling upwards toward you.
Locate the second antenna connection toward the middle right area of the back panel. It is found in the corner where the red and yellow tabbed pin strips met.
Remove the antenna connection using the same method done in the previous, top antenna removal step.
Loosen the bottom metal cable grip (which pins down the cable) to separate the antenna from the motherboard entirely.
Hold the middle panel and lift it away from the frame to separate the middle button panel from the screen and front frame.
Set the middle button panel aside after it has been fully separated from the screen.
Replace the volume control and convenience key buttons by replacing the entire middle panel.
Notice that the LCD/touchscreen is placed directly beneath the side button panel.
Prepare to remove the The LCD/touchscreen which rests directly on top of the front panel of the phone.
Remove the LCD/touchscreen by pulling it off of the front panel once you have located it. No tools are necessary.
3 farklı kişi bu kılavuzu tamamladı.
