Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Attaining access to your logic/motherboard will be taught in the details of this guide, good luck!
Neye ihtiyacın var
Locate the two switches toward the bottom corners of the device's back cover.
Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
Locate the SIM card once the battery has been removed. The SIM card is typically located in the center of the phone, and it is secured by a metal tray.
Place the opening tool underneath the camera lens' protective plastic cover and pry them apart with gentle force.
Make sure the plastic cover has been fully removed by carefully lifting it away from the device with your fingers.
Flip the device so that the touchscreen and Blackberry logo is facing you.
Place the opening tool underneath the front plastic cover located below the buttons with red and green phone symbols.
Lift and remove the plastic cover once the opening tool is in place. Make sure the plastic cover can be fully detached from the rest of the device.
Locate the red tabbed pin strip connected to the logic/motherboard. The red tabbed pin strip should be located on the right hand side of the back of the phone.
Using a spudger tool, disconnect the red tabbed pin strip from the logic/motherboard. This can be done by inserting the spudger tool under the side of the tab and gently pulling upwards towards you.
After removing the red tabbed pin strip, locate the the yellow tabbed pin strip. This should be directly under the red tabbed pin strip.
Disconnect the yellow tabbed pin strip from the logic/motherboard. This can be done using the same technique used to disconnect the red tabbed pin strip.
Now that the red and yellow pinned tabs have been disconnected, disconnect the antenna cable located at the top right of the phone.
The cable can be disconnected using the spudger tool.
Insert the spudger under the side of the antenna connection. Gently pull upwards to disconnect the cable.
Locate the second antenna connection. It can be found toward the middle/bottom right of the phone close to where the red and yellow tabbed pin strips were.
Remove the antenna connection. This can be done using the same method done in the top antenna removal step.
The antenna cable will still not be entirely disconnected from the logic/motherboard. To remove it entirely, loosen the bottom metal cable grip that pins down the cable.
Bir başkası bu kılavuzu tamamladı.
