Ana içeriğe geç
Blackberry Torch 9800 Logic Board Replacement
Neye ihtiyacın var
  1. Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: adım 1, 2 resimden 1. Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: adım 1, 2 resimden 2.
    • Remove the back cover and the battery.
    • Unscrew the four screws using a T6 screwdriver.
    • Removing the top right screw (with the blue cover) will void the warranty.
  2. Blackberry Torch 9800 Logic Board Replacement: adım 2, 2 resimden 1. Blackberry Torch 9800 Logic Board Replacement: adım 2, 2 resimden 2.
    • Remove the side trim using the plastic opening tool.
    • Apply pressure to push the top side of the side trim towards the phone while pulling the bottom away from the phone to remove the side trim.
    • The side trim is fragile and easily fractured, so handful it with care.
  3. Blackberry Torch 9800 Logic Board Replacement: adım 3, 3 resimden 1. Blackberry Torch 9800 Logic Board Replacement: adım 3, 3 resimden 2. Blackberry Torch 9800 Logic Board Replacement: adım 3, 3 resimden 3.
    • Remove the two screws that have been revealed at the top of the device using the T6 screwdriver.
    • You should now be able to easily lift the back panel from the phone.
  4. Blackberry Torch 9800 Logic Board Replacement: adım 4, 2 resimden 1. Blackberry Torch 9800 Logic Board Replacement: adım 4, 2 resimden 2.
    • Using your hands, carefully peel the three ribbon cable caps from the logic board.
  5. Blackberry Torch 9800 Logic Board Replacement: adım 5, 2 resimden 1. Blackberry Torch 9800 Logic Board Replacement: adım 5, 2 resimden 2.
    • Lift logic board slightly. The logic board will remain attached to the phone by a small antenna wire.
    • Using your hands, carefully lift the clasp attached to the antenna wire straight upward away from the logic board.
    • Make sure not to disconnect the antenna wire from its clasp.
    • The logic board should now be completely separate from the phone.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Keegan Williams
216 İtibar
2 adet Kılavuz yazıldı
Ekip
Ohio State, Team 1-5, Garvin Spring 2016 Ohio State, Team 1-5, Garvin Spring 2016 üyesi
OSU-GARVIN-S16S1G5
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 870
