Ana içeriğe geç
Blackberry Torch 9800 Replacing rear camera
Neye ihtiyacın var
  1. Blackberry Torch 9800 Replacing rear camera, Replacing rear camera: adım 1, 2 resimden 1. Blackberry Torch 9800 Replacing rear camera, Replacing rear camera: adım 1, 2 resimden 2.
    • Remove the back cover and the battery.
    • Remove the four exposed screws using a T7 screwdriver.
    • Warning: Removing the top right screw (with the blue cover) will void the warranty.
  2. Blackberry Torch 9800 Replacing rear camera: adım 2, 2 resimden 1. Blackberry Torch 9800 Replacing rear camera: adım 2, 2 resimden 2.
    • Remove the side trim using the plastic opening tool.
    • When loose, push the top backwards and the bottom forwards to remove.
  3. Blackberry Torch 9800 Replacing rear camera: adım 3, 3 resimden 1. Blackberry Torch 9800 Replacing rear camera: adım 3, 3 resimden 2. Blackberry Torch 9800 Replacing rear camera: adım 3, 3 resimden 3.
    • Two new screws have been exposed near the top of the back.
    • Remove the two screws using the T7 screwdriver.
    • Remove the back panel using the plastic opening tool.
  4. Blackberry Torch 9800 Replacing rear camera: adım 4, 2 resimden 1. Blackberry Torch 9800 Replacing rear camera: adım 4, 2 resimden 2.
    • Carefully use flathead screwdriver to free camera sensor.
    • Wiggle on the right and left sides, not the top and bottom sides.
  5. Blackberry Torch 9800 Replacing rear camera: adım 5, 1 resimden 1.
    • To install the new camera sensor, place in slot. Reassemble phone by doing steps 1-3 in reverse order.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0delete
183 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-5, Garvin Spring 2016 Ohio State, Team 1-5, Garvin Spring 2016 üyesi
OSU-GARVIN-S16S1G5
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 284
