Ana içeriğe geç
Blackberry Torch 9810 Cursor Key Replacement
Neye ihtiyacın var
  1. Blackberry Torch 9810 Cursor Key Replacement, Phone cover: adım 1, 2 resimden 1. Blackberry Torch 9810 Cursor Key Replacement, Phone cover: adım 1, 2 resimden 2.
    • Remove the back cover of the phone
    FixBot'a Sor
    Yorum Ekle
  2. Blackberry Torch 9810 Cursor Key Replacement, Battery: adım 2, 1 resimden 1.
    • Remove the battery
    FixBot'a Sor
    Yorum Ekle
  3. Blackberry Torch 9810 Cursor Key Replacement, Remove screws: adım 3, 1 resimden 1.
    • Unscrew the four screws using the T6 screw driver.
    • If you remove the screw in red, you void the warranty!
    FixBot'a Sor
    Yorum Ekle
  4. Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: adım 4, 2 resimden 1. Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: adım 4, 2 resimden 2.
    • Slide the screen up.
    • Remove front silver trim by using a plastic opening tools and wiggle it off.
    • This is difficult to remove, but it should come off if you do it with caution.
    FixBot'a Sor
    Yorum Ekle
  5. Blackberry Torch 9810 Cursor Key Replacement, More screws that need to go: adım 5, 1 resimden 1.
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them with a T-6 screw driver.
    FixBot'a Sor
    Yorum Ekle
  6. Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: adım 6, 3 resimden 1. Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: adım 6, 3 resimden 2. Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: adım 6, 3 resimden 3.
    • Use the plastic opening tools to remove the entire back off the phone.
    FixBot'a Sor
    Yorum Ekle
  7. Blackberry Torch 9810 Cursor Key Replacement, Remove Ribbon Cables: adım 7, 1 resimden 1.
    • Remove the three ribbon cables and the antenna wire by hand.
    • The cable in red is glued to the metal cap. Peel it upwards towards the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  8. Blackberry Torch 9810 Cursor Key Replacement, Remove Logic Board: adım 8, 1 resimden 1.
    • The logic board will easily pull straight out.
    FixBot'a Sor
    Yorum Ekle
  9. Blackberry Torch 9810 Cursor Key Replacement, Remove Informational Sticker: adım 9, 1 resimden 1.
    • Remove the black sticker located above the logic board that contains the phone's serial number
    FixBot'a Sor
    Yorum Ekle
  10. Blackberry Torch 9810 Cursor Key Replacement, Remove More Screws: adım 10, 1 resimden 1.
    • Behind the black sticker you should find six small yellow screws. Remove them with a T4 torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  11. Blackberry Torch 9810 Cursor Key Replacement, Separate the phone: adım 11, 1 resimden 1.
    • Carefully separate the screen from the body.
    • Make sure to be extra careful with the ribbon!
    FixBot'a Sor
    Yorum Ekle
  12. Blackberry Torch 9810 Cursor Key Replacement: adım 12, 1 resimden 1.
    • Slide the silver plate up and you should find four more screws that need to be removed. Use a T-4 screw driver.
    • They are on a black cover located on the bottom of the phone. The black cover will come off
    FixBot'a Sor
    Yorum Ekle
  13. Blackberry Torch 9810 Cursor Key Replacement, Carefully Remove a Ribbion: adım 13, 1 resimden 1.
    • There is one last orange ribbon cable that needs to be pulled and behind it is the cursor
    FixBot'a Sor
    Yorum Ekle
  14. Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: adım 14, 3 resimden 1. Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: adım 14, 3 resimden 2. Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: adım 14, 3 resimden 3.
    • Push the cursor upwards and out of the socket.
    • Gently pull out the white box by pulling straight out of the socket to the right. This is your cursor
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jocelyn Adorno
314 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G6
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 1,795
