Ana içeriğe geç
Blackberry Torch 9810 Cursor Key Replacement
Neye ihtiyacın var
  1. Blackberry Torch 9810 Cursor Key Replacement, Phone cover: adım 1, 2 resimden 1. Blackberry Torch 9810 Cursor Key Replacement, Phone cover: adım 1, 2 resimden 2.
    • Remove the back cover of the phone
  2. Blackberry Torch 9810 Cursor Key Replacement, Battery: adım 2, 1 resimden 1.
    • Remove the battery
  3. Blackberry Torch 9810 Cursor Key Replacement, Remove screws: adım 3, 1 resimden 1.
    • Unscrew the four screws using the T6 screw driver.
    • If you remove the screw in red, you void the warranty!
  4. Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: adım 4, 2 resimden 1. Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: adım 4, 2 resimden 2.
    • Slide the screen up.
    • Remove front silver trim by using a plastic opening tools and wiggle it off.
    • This is difficult to remove, but it should come off if you do it with caution.
  5. Blackberry Torch 9810 Cursor Key Replacement, More screws that need to go: adım 5, 1 resimden 1.
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them with a T-6 screw driver.
  6. Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: adım 6, 3 resimden 1. Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: adım 6, 3 resimden 2. Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: adım 6, 3 resimden 3.
    • Use the plastic opening tools to remove the entire back off the phone.
  7. Blackberry Torch 9810 Cursor Key Replacement, Remove Ribbon Cables: adım 7, 1 resimden 1.
    • Remove the three ribbon cables and the antenna wire by hand.
    • The cable in red is glued to the metal cap. Peel it upwards towards the battery compartment.
  8. Blackberry Torch 9810 Cursor Key Replacement, Remove Logic Board: adım 8, 1 resimden 1.
    • The logic board will easily pull straight out.
  9. Blackberry Torch 9810 Cursor Key Replacement, Remove Informational Sticker: adım 9, 1 resimden 1.
    • Remove the black sticker located above the logic board that contains the phone's serial number
  10. Blackberry Torch 9810 Cursor Key Replacement, Remove More Screws: adım 10, 1 resimden 1.
    • Behind the black sticker you should find six small yellow screws. Remove them with a T4 torx screwdriver.
  11. Blackberry Torch 9810 Cursor Key Replacement, Separate the phone: adım 11, 1 resimden 1.
    • Carefully separate the screen from the body.
    • Make sure to be extra careful with the ribbon!
  12. Blackberry Torch 9810 Cursor Key Replacement: adım 12, 1 resimden 1.
    • Slide the silver plate up and you should find four more screws that need to be removed. Use a T-4 screw driver.
    • They are on a black cover located on the bottom of the phone. The black cover will come off
  13. Blackberry Torch 9810 Cursor Key Replacement, Carefully Remove a Ribbion: adım 13, 1 resimden 1.
    • There is one last orange ribbon cable that needs to be pulled and behind it is the cursor
  14. Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: adım 14, 3 resimden 1. Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: adım 14, 3 resimden 2. Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: adım 14, 3 resimden 3.
    • Push the cursor upwards and out of the socket.
    • Gently pull out the white box by pulling straight out of the socket to the right. This is your cursor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jocelyn Adorno
296 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 1,476
