Giriş
I will demonstrate the process of replacing the fan of a Blackstone Cascade Pro Personal Fan. Over time when a fan is exposed to excessive use the fan can be damaged. I will show people how to restore their fans to working order.
I believe this guide is needed because a damaged fan can be a major problem. If it is damaged it can potentially cause the entire fan to break and replacing it can often be very expensive. Replacing the main fan can help environmental waste and save you money.
Neye ihtiyacın var
Remove the four screws surrounding the back of the Blackstone fan using a Phillips #00 screwdriver.
Remove the cover at the back of the fan.
2 farklı kişi bu kılavuzu tamamladı.
