Ana içeriğe geç
Blackstone Cascade Pro Fan Replacement
Neye ihtiyacın var
  1. Blackstone Cascade Pro Fan Replacement, Fan: adım 1, 3 resimden 1. Blackstone Cascade Pro Fan Replacement, Fan: adım 1, 3 resimden 2. Blackstone Cascade Pro Fan Replacement, Fan: adım 1, 3 resimden 3.
    • Remove the four screws surrounding the back of the Blackstone fan using a Phillips #00 screwdriver.
    • Remove the cover at the back of the fan.
  2. Blackstone Cascade Pro Fan Replacement: adım 2, 2 resimden 1. Blackstone Cascade Pro Fan Replacement: adım 2, 2 resimden 2.
    • Remove the diamond cover at the top of the fan.
    • The diamond cover will be connected to a set of wires to the fan. Simply place the cover to the side for the rest of the repair.
  3. Blackstone Cascade Pro Fan Replacement: adım 3, 3 resimden 1. Blackstone Cascade Pro Fan Replacement: adım 3, 3 resimden 2. Blackstone Cascade Pro Fan Replacement: adım 3, 3 resimden 3.
    • Remove the two screws that are holding the spherical cover shielding the main fan using a Phillips #00 screwdriver.
    • Remove the spherical cover surrounding the main fan.
  4. Blackstone Cascade Pro Fan Replacement: adım 4, 2 resimden 1. Blackstone Cascade Pro Fan Replacement: adım 4, 2 resimden 2.
    • On the opposite side there will be a cover identical to the one removed in the previous step.
    • Twist the main fan to remove the cover on the opposite side.
  5. Blackstone Cascade Pro Fan Replacement: adım 5, 3 resimden 1. Blackstone Cascade Pro Fan Replacement: adım 5, 3 resimden 2. Blackstone Cascade Pro Fan Replacement: adım 5, 3 resimden 3.
    • Using the socket wrench, and a size 10 shallow socket, remove the hexagon screw at the center of the main fan.
    • Pull out the main fan.
    • Depending on the age of your fan, it may require more strength to pull it out. Be careful to not use too much force.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mohamed Mallah
148 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 309
