Ana içeriğe geç
Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement
Neye ihtiyacın var
  1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: adım 1, 3 resimden 1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: adım 1, 3 resimden 2. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: adım 1, 3 resimden 3.
    • Make sure the diffuser is not plugged into a socket and that there is no water or oil near or in the diffuser before beginning the guide.
    • Use a Phillips #2 screwdriver to remove the four 8 mm screws on the bottom of the diffuser.
  2. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 2, 3 resimden 1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 2, 3 resimden 2. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 2, 3 resimden 3.
    • Lift the ceramic top of the oil diffuser.
    • Then lift off the plastic top off the diffuser.
  3. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 3, 3 resimden 1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 3, 3 resimden 2. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 3, 3 resimden 3.
    • Lift the last plastic lid.
    • You will see a circuit board, and there will be a cord connecting it to the circuit board.
  4. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 4, 2 resimden 1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 4, 2 resimden 2.
    • Gently unplug the cord from the circuit board.
    • Place the plastic lid somewhere safe on the a flat surface.
  5. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 5, 3 resimden 1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 5, 3 resimden 2. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 5, 3 resimden 3.
    • Remove the plastic ring and place somewhere safe on a flat surface.
  6. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 6, 3 resimden 1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 6, 3 resimden 2. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 6, 3 resimden 3.
    • Remove two Truss head 4 mm screws with a Phillips #2 screwdriver and place safely nearby.
  7. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 7, 3 resimden 1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 7, 3 resimden 2. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 7, 3 resimden 3.
    • Gently lift the circuit board onto it's side
    • The white connector plugs the fan into the circuit board.
  8. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 8, 2 resimden 1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 8, 2 resimden 2.
    • Unplug the white connector.
    • There are four #M1 6 mm Phillips pan head screws holding down the fan.
  9. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 9, 3 resimden 1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 9, 3 resimden 2. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: adım 9, 3 resimden 3.
    • Remove the #M1 6 mm screws with a Phillips #2 screwdriver while holding down the fan.
    • Gently lift the fan and place the fan someplace safe on the flat surface.
Sonuç
Muniira Mohamoud
169 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 398
