Ana içeriğe geç
Blu Dash 5.0 Dual SIM Back Camera Replacement
Neye ihtiyacın var
  1. Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: adım 1, 2 resimden 1. Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: adım 1, 2 resimden 2.
    • Make sure device is disconnected and turned off.
    • Locate the groove on the bottom left corner of the back of the phone.
    • Insert the plastic opening tool into the groove and pry it open.
    • Lift the back cover of the phone using your hands.
  2. Blu Dash 5.0 Dual SIM Back Camera Replacement: adım 2, 1 resimden 1.
    • Pry the battery out using the plastic opening tool.
  3. Blu Dash 5.0 Dual SIM Back Camera Replacement: adım 3, 1 resimden 1.
    • Remove the 12 screws on the back panel using a J000 screwdriver.
    • Red circles correspond to the screw holes holding 3.5 mm length Phillips screws.
    • Orange circles correspond to the screw holes holding 2.5 mm length Phillips screws.
  4. Blu Dash 5.0 Dual SIM Back Camera Replacement: adım 4, 3 resimden 1. Blu Dash 5.0 Dual SIM Back Camera Replacement: adım 4, 3 resimden 2. Blu Dash 5.0 Dual SIM Back Camera Replacement: adım 4, 3 resimden 3.
    • Peel off the back panel with your hand.
    • Remove the back panel slowly to avoid breaking it.
  5. Blu Dash 5.0 Dual SIM Back Camera Replacement: adım 5, 3 resimden 1. Blu Dash 5.0 Dual SIM Back Camera Replacement: adım 5, 3 resimden 2. Blu Dash 5.0 Dual SIM Back Camera Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Flip up the ZIF flap using the spudger.
    • Gently remove the ribbon cable with tweezers.
    • The ribbon cable is sensitve and needs to be removed carefully to insure its integrity.
    • Remove the back camera using tweezers.
Sonuç
Mukish Kumar Munyady
201 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Baechle Spring 2017 IUPUI, Team 1-1, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S1G1
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 377
