Ana içeriğe geç
Blu Dash 5.0 Dual SIM Battery Replacement
Neye ihtiyacın var
  1. Blu Dash 5.0 Dual SIM Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Find the small slot on the bottom left corner of the back panel.
    • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
    • When the back panel is loose enough, use your fingers to remove it completely.
  2. Blu Dash 5.0 Dual SIM Battery Replacement: adım 2, 1 resimden 1.
    • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Dashaya Toney
876 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-7, Miles Fall 2014 UMass Dartmouth, Team 4-7, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G7
3 Üyeler
Bir Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 4,053
