Giriş
Outline what you are going to teach someone how to do.
Neye ihtiyacın var
Find the small slot on the bottom left corner of the back panel.
Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
When the back panel is loose enough, use your fingers to remove it completely.
5 farklı kişi bu kılavuzu tamamladı.
If slot 1 is messed up can you use slot 2 for simcard and the phone still work
Margie White - Yanıt
