Ana içeriğe geç
Blu Dash 5.0 Dual SIM Speaker Replacement
Neye ihtiyacın var
  1. Blu Dash 5.0 Dual SIM Speaker Replacement, Speaker: adım 1, 2 resimden 1. Blu Dash 5.0 Dual SIM Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Make sure device is disconnected and turned off.
    • Locate the groove at the bottom left corner of the phone.
    • Insert the plastic opening tool in the groove and pry it open.
    • Lift the back cover of the phone using your hands.
  2. Blu Dash 5.0 Dual SIM Speaker Replacement: adım 2, 1 resimden 1.
    • Pry the battery out from the back of the phone using the plastic opening tool.
  3. Blu Dash 5.0 Dual SIM Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the 12 screws located at the back panel of the phone using a J000 screwdriver.
    • The red circles are screw holes that hold the 3.5mm length Phillips screw.
    • The orange circles are screw holes that hold the 2.5mm length Phillips screw.
  4. Blu Dash 5.0 Dual SIM Speaker Replacement: adım 4, 3 resimden 1. Blu Dash 5.0 Dual SIM Speaker Replacement: adım 4, 3 resimden 2. Blu Dash 5.0 Dual SIM Speaker Replacement: adım 4, 3 resimden 3.
    • Remove the back panel of the phone with your hand.
    • Carefully remove the plastic back panel to avoid breaking it.
  5. Blu Dash 5.0 Dual SIM Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the antenna cable connectors using a spudger.
  6. Blu Dash 5.0 Dual SIM Speaker Replacement: adım 6, 1 resimden 1.
    • Unscrew the 2.5mm screws from the circuit board holding the speaker at the bottom of the phone.
  7. Blu Dash 5.0 Dual SIM Speaker Replacement: adım 7, 2 resimden 1. Blu Dash 5.0 Dual SIM Speaker Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Flip the ZIF flap up with tweezers.
    • Remove the ribbon cable with tweezers.
    • The ribbon cable is sensitive and needs to be removed carefully to insure its integrity.
  8. Blu Dash 5.0 Dual SIM Speaker Replacement: adım 8, 2 resimden 1. Blu Dash 5.0 Dual SIM Speaker Replacement: adım 8, 2 resimden 2.
    • Remove the speaker panel with the plastic opening tool.
    • The panel is glued onto the device and will require extra force to remove.
Sonuç
Mukish Kumar Munyady
201 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Baechle Spring 2017 IUPUI, Team 1-1, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S1G1
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 276
