Ana içeriğe geç
Blu Grand M Motherboard Replacement
Neye ihtiyacın var
  1. Blu Grand M Motherboard Replacement, Battery: adım 1, 2 resimden 1. Blu Grand M Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Motherboard Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Motherboard Replacement: adım 3, 3 resimden 1. Blu Grand M Motherboard Replacement: adım 3, 3 resimden 2. Blu Grand M Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Motherboard Replacement: adım 4, 2 resimden 1. Blu Grand M Motherboard Replacement: adım 4, 2 resimden 2.
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  5. Blu Grand M Motherboard Replacement, Plastic Plate: adım 5, 2 resimden 1. Blu Grand M Motherboard Replacement, Plastic Plate: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the yellow plastic tape using a pair of tweezers.
  6. Blu Grand M Motherboard Replacement: adım 6, 3 resimden 1. Blu Grand M Motherboard Replacement: adım 6, 3 resimden 2. Blu Grand M Motherboard Replacement: adım 6, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove two black 4.0mm screws.
    • Use a Phillips #000 screwdriver to remove 2 silver 4.0mm screws
    • Remove the plastic cover along the top by tugging on it on the corner as shown.
  7. Blu Grand M Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. Blu Grand M Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Place a spudger or other tool underneath the black wire.
    • Lift up on the gold coaxial cable connector so it disconnects from the motherboard.
  8. Blu Grand M Motherboard Replacement: adım 8, 3 resimden 1. Blu Grand M Motherboard Replacement: adım 8, 3 resimden 2. Blu Grand M Motherboard Replacement: adım 8, 3 resimden 3.
    • Using the the narrow tip of a nylon spudger, open the two cable connector ports.
  9. Blu Grand M Motherboard Replacement: adım 9, 2 resimden 1. Blu Grand M Motherboard Replacement: adım 9, 2 resimden 2.
    • Insert the spudger underneath the ribbon cable.
    • Pull the ribbon cable away from the gray connector.
    • The cable should pull away free from the gray connector without any resistance.
    • If you encounter resistance, check to see that the black cable connector port is open.
  10. Blu Grand M Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the four 4.0mm screws with a Philips #000 screwdriver.
  11. Blu Grand M Motherboard Replacement: adım 11, 2 resimden 1. Blu Grand M Motherboard Replacement: adım 11, 2 resimden 2.
    Satın Al
    • Lift the motherboard up and slightly away from the smartphone frame using the nylon tipped tweezers or other ESD safe tool.
    • The motherboard is still connected to the frame via a large black ribbon cable. Do not lift higher than this ribbon allows.
    • Flip the motherboard upside down to reveal the ribbon cable connector.
  12. Blu Grand M Motherboard Replacement: adım 12, 2 resimden 1. Blu Grand M Motherboard Replacement: adım 12, 2 resimden 2.
    • A large black ribbon cable is connected to the underside of the motherboard.
    • Use the spudger to open the orange plastic ribbon connector.
  13. Blu Grand M Motherboard Replacement: adım 13, 2 resimden 1. Blu Grand M Motherboard Replacement: adım 13, 2 resimden 2.
    • Insert the spudger into the folded ribbon cable loop.
    • Pull the ribbon cable away from the black plastic connector.
    • The ribbon cable should pull away from the black connector without any resistance.
  14. Blu Grand M Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the motherboard with the nylon tweezers.
    • Place the motherboard on an electrostatic discharge (ESD) safe material.
Sonuç
To reassemble your, follow these instructions in reverse order.
Note: The ribbon clamp connector, also known as a Zero Insertion Force (ZIF) connector, might be difficult to reinsert. Follow the reinstallation step at the end of this guide: Recognizing & Disconnecting Cable Connectors.
Liam Rollins
253 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 226
