Ana içeriğe geç
Blu Grand M Speaker Replacement
Neye ihtiyacın var
  1. Blu Grand M Speaker Replacement, Battery: adım 1, 2 resimden 1. Blu Grand M Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Speaker Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Speaker Replacement: adım 3, 3 resimden 1. Blu Grand M Speaker Replacement: adım 3, 3 resimden 2. Blu Grand M Speaker Replacement: adım 3, 3 resimden 3.
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Speaker Replacement: adım 4, 2 resimden 1. Blu Grand M Speaker Replacement: adım 4, 2 resimden 2.
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  5. Blu Grand M Speaker Replacement, Speaker: adım 5, 2 resimden 1. Blu Grand M Speaker Replacement, Speaker: adım 5, 2 resimden 2.
    • Remove the exterior cover with a Torx 2 screwdriver, to remove two 3.0mm screws.
    • Remove the 4.0mm screw with a Phillips #000 screwdriver.
    • Using the blue plastic opening tool, remove the exterior cover.
  6. Blu Grand M Speaker Replacement: adım 6, 3 resimden 1. Blu Grand M Speaker Replacement: adım 6, 3 resimden 2. Blu Grand M Speaker Replacement: adım 6, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove each of the four 1.5mm screws.
    • Use a Phillips #000 screwdriver to remove each of the three 3.0mm screws.
    • Use the plastic opening tool to remove the speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cameron Retzlaff
608 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 97
