Ana içeriğe geç
Blu Grand M2 Display Replacement
Neye ihtiyacın var
  1. Blu Grand M2 Display Replacement, Display: adım 1, 2 resimden 1. Blu Grand M2 Display Replacement, Display: adım 1, 2 resimden 2.
    • Before beginning the guide, be sure that this replacement guide addresses your specific problem.
    • Locate the two Torx screws at the bottom of the phone and remove them.
    FixBot'a Sor
    Yorum Ekle
  2. Blu Grand M2 Display Replacement: adım 2, 1 resimden 1.
    • Use the pry tool to wedge between the phone's frame and the back plate.
    • Carefully remove the back plate using the suction tool.
    • Be careful not to damage the phone display and/or the inside components while using the pry tool and the suction tool.
    FixBot'a Sor
    Yorum Ekle
  3. Blu Grand M2 Display Replacement: adım 3, 3 resimden 1. Blu Grand M2 Display Replacement: adım 3, 3 resimden 2. Blu Grand M2 Display Replacement: adım 3, 3 resimden 3.
    • Once the back panel is removed, locate the connector of the display shown in figure 1 on the motherboard side.
    • There will be an orange sticker above the previously mentioned connector. You can gently lift the connector up to release it.
    • Disconnect the two remaining connectors shown in figure 3.
    FixBot'a Sor
    Yorum Ekle
  4. Blu Grand M2 Display Replacement: adım 4, 2 resimden 1. Blu Grand M2 Display Replacement: adım 4, 2 resimden 2.
    • After removing the connectors, locate the six Phillips screws on the motherboard side and remove them.
    • After removing the six Phillips screws, remove the motherboard piece.
    FixBot'a Sor
    Yorum Ekle
  5. Blu Grand M2 Display Replacement: adım 5, 1 resimden 1.
    • Once you have removed the motherboard piece, flip the phone so the screen is facing up and begin using the iOpener.
    • Heat up the iOpener from the iFixit kit for 30 seconds in a microwave and apply it on top of the screen to loosen the phone's adhesive.
    • The iOpener can be hot once it is microwaved. Make sure to wear gloves and other safety equipment to prevent any burns.
    FixBot'a Sor
    Yorum Ekle
  6. Blu Grand M2 Display Replacement: adım 6, 3 resimden 1. Blu Grand M2 Display Replacement: adım 6, 3 resimden 2. Blu Grand M2 Display Replacement: adım 6, 3 resimden 3.
    • Using the suction tool, slowly pull out the display screen shown in figure 1.
    • Use the pry tool to completely detach the display screen from the phone.
    • When the display is removed, attach your new screen.
    • After applying the new screen, use the steps in reverse order to reassemble the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Christopher
192 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team S1-G3, Luster Fall 2018 Gateway, Team S1-G3, Luster Fall 2018 üyesi
GCC-LUSTER-F18S1G3
4 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
What type of torx screwdriver did you use?
npyles86 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 35
Her zaman: 2,201
