Ana içeriğe geç
Blu Grand M2 Display Replacement
Neye ihtiyacın var
  1. Blu Grand M2 Display Replacement, Display: adım 1, 2 resimden 1. Blu Grand M2 Display Replacement, Display: adım 1, 2 resimden 2.
    • Before beginning the guide, be sure that this replacement guide addresses your specific problem.
    • Locate the two Torx screws at the bottom of the phone and remove them.
  2. Blu Grand M2 Display Replacement: adım 2, 1 resimden 1.
    • Use the pry tool to wedge between the phone's frame and the back plate.
    • Carefully remove the back plate using the suction tool.
    • Be careful not to damage the phone display and/or the inside components while using the pry tool and the suction tool.
  3. Blu Grand M2 Display Replacement: adım 3, 3 resimden 1. Blu Grand M2 Display Replacement: adım 3, 3 resimden 2. Blu Grand M2 Display Replacement: adım 3, 3 resimden 3.
    • Once the back panel is removed, locate the connector of the display shown in figure 1 on the motherboard side.
    • There will be an orange sticker above the previously mentioned connector. You can gently lift the connector up to release it.
    • Disconnect the two remaining connectors shown in figure 3.
  4. Blu Grand M2 Display Replacement: adım 4, 2 resimden 1. Blu Grand M2 Display Replacement: adım 4, 2 resimden 2.
    • After removing the connectors, locate the six Phillips screws on the motherboard side and remove them.
    • After removing the six Phillips screws, remove the motherboard piece.
  5. Blu Grand M2 Display Replacement: adım 5, 1 resimden 1.
    • Once you have removed the motherboard piece, flip the phone so the screen is facing up and begin using the iOpener.
    • Heat up the iOpener from the iFixit kit for 30 seconds in a microwave and apply it on top of the screen to loosen the phone's adhesive.
    • The iOpener can be hot once it is microwaved. Make sure to wear gloves and other safety equipment to prevent any burns.
  6. Blu Grand M2 Display Replacement: adım 6, 3 resimden 1. Blu Grand M2 Display Replacement: adım 6, 3 resimden 2. Blu Grand M2 Display Replacement: adım 6, 3 resimden 3.
    • Using the suction tool, slowly pull out the display screen shown in figure 1.
    • Use the pry tool to completely detach the display screen from the phone.
    • When the display is removed, attach your new screen.
    • After applying the new screen, use the steps in reverse order to reassemble the phone.
Sonuç
Christopher
192 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team S1-G3, Luster Fall 2018 Gateway, Team S1-G3, Luster Fall 2018 üyesi
GCC-LUSTER-F18S1G3
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
What type of torx screwdriver did you use?
npyles86 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,726
