Ana içeriğe geç
Blu L120 Loudspeaker Replacement
Neye ihtiyacın var
  1. Blu L120 Loudspeaker Replacement, Open the back panel: adım 1, 3 resimden 1. Blu L120 Loudspeaker Replacement, Open the back panel: adım 1, 3 resimden 2. Blu L120 Loudspeaker Replacement, Open the back panel: adım 1, 3 resimden 3.
    • Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up.
  2. Blu L120 Loudspeaker Replacement, Screw removal: adım 2, 3 resimden 1. Blu L120 Loudspeaker Replacement, Screw removal: adım 2, 3 resimden 2. Blu L120 Loudspeaker Replacement, Screw removal: adım 2, 3 resimden 3.
    • Remove these nine screws with a small philips screwdriver. They are all of the same size
    • There is a small screw hidden under the warranty sticker. You may either remove or poke through it.
    • *WARNING* by doing this you will void your manufacturer warranty.
  3. Blu L120 Loudspeaker Replacement, Rear panel removal: adım 3, 3 resimden 1. Blu L120 Loudspeaker Replacement, Rear panel removal: adım 3, 3 resimden 2. Blu L120 Loudspeaker Replacement, Rear panel removal: adım 3, 3 resimden 3.
    • Use the Spudger to gently separate the panel from the frame, starting from the bottom left corner.
    • Then work your way along the edges of the phone.
  4. Blu L120 Loudspeaker Replacement, Separate back panel and frame: adım 4, 3 resimden 1. Blu L120 Loudspeaker Replacement, Separate back panel and frame: adım 4, 3 resimden 2. Blu L120 Loudspeaker Replacement, Separate back panel and frame: adım 4, 3 resimden 3.
    • Continue using the spudger around the back panel of the phone to separate both pieces.
    • Once you have gone around the entire frame, use both hands to pull it apart.
  5. Blu L120 Loudspeaker Replacement, Speaker Removal: adım 5, 2 resimden 1. Blu L120 Loudspeaker Replacement, Speaker Removal: adım 5, 2 resimden 2.
    • Use a pair of tweezers to grab the speaker assembly from the back of the panel and gently remove the it from the frame. (double sided tape is used to hold it together)
    • Install the new speaker, and follow the guide in reverse to reassemble the phone.
Sonuç
Julio
695 İtibar
6 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-5, Johnson Fall 2014 Gateway, Team 1-5, Johnson Fall 2014 üyesi
GCC-JOHNSON-F14S1G5
3 Üyeler
Bir Yorum
where can i get the Loud speaker
Shamar Houston - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 271
