Giriş
This guide will be helpful if your camera has become cloudy and in need of cleaning, or even if it needs to be replaced outright.
Neye ihtiyacın var
Adım 1 Battery
Dikkatli ol: adımlar 1-2 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Flip over your Studio 5.5 so the back is facing you.
Use either the spudger or your fingernail to pull up on the slot in the lower left corner and remove the back cover.
Begin by removing the 12 3.5mm screws along the back of the device.
1 of these screws will be underneath a white sticker. Just press the screwdriver through it and remove it normally.
3 farklı kişi bu kılavuzu tamamladı.
