Ana içeriğe geç
Blu Studio 5.5 S Back Case Replacement
  1. Blu Studio 5.5 S Back Case Replacement, Back Casing: adım 1, 1 resimden 1.
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Back Case Replacement, Applying Pressure: adım 2, 3 resimden 1. Blu Studio 5.5 S Back Case Replacement, Applying Pressure: adım 2, 3 resimden 2. Blu Studio 5.5 S Back Case Replacement, Applying Pressure: adım 2, 3 resimden 3.
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
Sonuç
To reassemble your device, insert the two tabs located at the bottom of the cover into the indents at the bottom of the phone. Then, press down on all sides of the phone until you hear it snap into place.
Bir başkası bu kılavuzu tamamladı.
Armen Garabedian
162 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-8, Miles Fall 2014 UMass Dartmouth, Team 4-8, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G8
2 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 1,047
