Ana içeriğe geç
Blu Studio 5.5 S Battery Replacement
  1. Blu Studio 5.5 S Battery Replacement, Back Casing: adım 1, 1 resimden 1.
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Battery Replacement, Applying Pressure: adım 2, 3 resimden 1. Blu Studio 5.5 S Battery Replacement, Applying Pressure: adım 2, 3 resimden 2. Blu Studio 5.5 S Battery Replacement, Applying Pressure: adım 2, 3 resimden 3.
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Battery Replacement, Battery: adım 3, 3 resimden 1. Blu Studio 5.5 S Battery Replacement, Battery: adım 3, 3 resimden 2. Blu Studio 5.5 S Battery Replacement, Battery: adım 3, 3 resimden 3.
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Cody Dyl
804 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-8, Miles Fall 2014 UMass Dartmouth, Team 4-8, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G8
2 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 6,138
