Ana içeriğe geç
Blu Studio 5.5 S Front Facing Camera Replacement
Neye ihtiyacın var
  1. Blu Studio 5.5 S Front Facing Camera Replacement, Back Casing: adım 1, 1 resimden 1.
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Front Facing Camera Replacement, Applying Pressure: adım 2, 3 resimden 1. Blu Studio 5.5 S Front Facing Camera Replacement, Applying Pressure: adım 2, 3 resimden 2. Blu Studio 5.5 S Front Facing Camera Replacement, Applying Pressure: adım 2, 3 resimden 3.
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Front Facing Camera Replacement, Battery: adım 3, 3 resimden 1. Blu Studio 5.5 S Front Facing Camera Replacement, Battery: adım 3, 3 resimden 2. Blu Studio 5.5 S Front Facing Camera Replacement, Battery: adım 3, 3 resimden 3.
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Front Facing Camera Replacement, Midframe: adım 4, 3 resimden 1. Blu Studio 5.5 S Front Facing Camera Replacement, Midframe: adım 4, 3 resimden 2. Blu Studio 5.5 S Front Facing Camera Replacement, Midframe: adım 4, 3 resimden 3.
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Front Facing Camera Replacement, Aesthetic Bottom Case: adım 5, 1 resimden 1.
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Front Facing Camera Replacement: adım 6, 3 resimden 1. Blu Studio 5.5 S Front Facing Camera Replacement: adım 6, 3 resimden 2. Blu Studio 5.5 S Front Facing Camera Replacement: adım 6, 3 resimden 3.
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Front Facing Camera Replacement, Frontward Facing Camera: adım 7, 2 resimden 1. Blu Studio 5.5 S Front Facing Camera Replacement, Frontward Facing Camera: adım 7, 2 resimden 2.
    • The frontward facing camera is located in the top left of the phone. It is connected to the motherboard by a ribbon connector, and a prong system.
    • Use a spudger to detach the front facing camera by flipping the orange tab on the top of the prong system.
    • Once the orange tab is up, pull out the orange ribbon wire.
  8. Blu Studio 5.5 S Front Facing Camera Replacement: adım 8, 2 resimden 1. Blu Studio 5.5 S Front Facing Camera Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to pick up the ribbon wire, and lift. The frontward facing camera will follow suit.
Sonuç
Cody Dyl
804 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-8, Miles Fall 2014 UMass Dartmouth, Team 4-8, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G8
2 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 1,574
