Ana içeriğe geç
Blu Studio 5.5 S Motherboard Replacement
Neye ihtiyacın var
  1. Blu Studio 5.5 S Motherboard Replacement, Back Casing: adım 1, 1 resimden 1.
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Motherboard Replacement, Applying Pressure: adım 2, 3 resimden 1. Blu Studio 5.5 S Motherboard Replacement, Applying Pressure: adım 2, 3 resimden 2. Blu Studio 5.5 S Motherboard Replacement, Applying Pressure: adım 2, 3 resimden 3.
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Motherboard Replacement, Battery: adım 3, 3 resimden 1. Blu Studio 5.5 S Motherboard Replacement, Battery: adım 3, 3 resimden 2. Blu Studio 5.5 S Motherboard Replacement, Battery: adım 3, 3 resimden 3.
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Motherboard Replacement, Midframe: adım 4, 3 resimden 1. Blu Studio 5.5 S Motherboard Replacement, Midframe: adım 4, 3 resimden 2. Blu Studio 5.5 S Motherboard Replacement, Midframe: adım 4, 3 resimden 3.
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Motherboard Replacement, Aesthetic Bottom Case: adım 5, 1 resimden 1.
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Motherboard Replacement: adım 6, 3 resimden 1. Blu Studio 5.5 S Motherboard Replacement: adım 6, 3 resimden 2. Blu Studio 5.5 S Motherboard Replacement: adım 6, 3 resimden 3.
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Motherboard Replacement, Motherboard: adım 7, 3 resimden 1. Blu Studio 5.5 S Motherboard Replacement, Motherboard: adım 7, 3 resimden 2. Blu Studio 5.5 S Motherboard Replacement, Motherboard: adım 7, 3 resimden 3.
    • Remove the three 7 mm screws using the Phillips #00 Screwdiver.
    • Disconnect motherboard plug connector near bottom right of battery using fingers to pull off the cap plug.
  8. Blu Studio 5.5 S Motherboard Replacement: adım 8, 3 resimden 1. Blu Studio 5.5 S Motherboard Replacement: adım 8, 3 resimden 2. Blu Studio 5.5 S Motherboard Replacement: adım 8, 3 resimden 3.
    • Use the nylon spudger to lift the release tabs by carefully grabbing the tabs from the sides and lifting up.
    • Release the four ribbon wires from the motherboard.
  9. Blu Studio 5.5 S Motherboard Replacement: adım 9, 2 resimden 1. Blu Studio 5.5 S Motherboard Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to grip the bottom of the motherboard and lift up.
Sonuç
After the final step has been completed, the replacement motherboard can then be put in place of the old one. To reassemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Guna Sathyamurthy
138 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Wilson Spring 2017 IUPUI, Team S2-G2, Wilson Spring 2017 üyesi
IUPUI-WILSON-S17S2G2
5 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 517
