Ana içeriğe geç
Blu Studio 5.5 S Screen Replacement
Neye ihtiyacın var
  1. Blu Studio 5.5 S Screen Replacement, Back Casing: adım 1, 1 resimden 1.
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Screen Replacement, Applying Pressure: adım 2, 3 resimden 1. Blu Studio 5.5 S Screen Replacement, Applying Pressure: adım 2, 3 resimden 2. Blu Studio 5.5 S Screen Replacement, Applying Pressure: adım 2, 3 resimden 3.
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Screen Replacement, Battery: adım 3, 3 resimden 1. Blu Studio 5.5 S Screen Replacement, Battery: adım 3, 3 resimden 2. Blu Studio 5.5 S Screen Replacement, Battery: adım 3, 3 resimden 3.
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Screen Replacement, Midframe: adım 4, 3 resimden 1. Blu Studio 5.5 S Screen Replacement, Midframe: adım 4, 3 resimden 2. Blu Studio 5.5 S Screen Replacement, Midframe: adım 4, 3 resimden 3.
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Screen Replacement, Aesthetic Bottom Case: adım 5, 1 resimden 1.
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Screen Replacement: adım 6, 3 resimden 1. Blu Studio 5.5 S Screen Replacement: adım 6, 3 resimden 2. Blu Studio 5.5 S Screen Replacement: adım 6, 3 resimden 3.
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Screen Replacement, Motherboard: adım 7, 3 resimden 1. Blu Studio 5.5 S Screen Replacement, Motherboard: adım 7, 3 resimden 2. Blu Studio 5.5 S Screen Replacement, Motherboard: adım 7, 3 resimden 3.
    • Remove the three 7 mm screws using the Phillips #00 Screwdiver.
    • Disconnect motherboard plug connector near bottom right of battery using fingers to pull off the cap plug.
  8. Blu Studio 5.5 S Screen Replacement: adım 8, 3 resimden 1. Blu Studio 5.5 S Screen Replacement: adım 8, 3 resimden 2. Blu Studio 5.5 S Screen Replacement: adım 8, 3 resimden 3.
    • Use the nylon spudger to lift the release tabs by carefully grabbing the tabs from the sides and lifting up.
    • Release the four ribbon wires from the motherboard.
  9. Blu Studio 5.5 S Screen Replacement: adım 9, 2 resimden 1. Blu Studio 5.5 S Screen Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to grip the bottom of the motherboard and lift up.
  10. Blu Studio 5.5 S Screen Replacement, Screen: adım 10, 2 resimden 1. Blu Studio 5.5 S Screen Replacement, Screen: adım 10, 2 resimden 2.
    • Remove speaker circuit board from bottom of the phone by using a Spudger to gently lift up.
    • The speaker circuit board is attached with adhesive. Be careful not to break when removing.
    • Once this piece is removed, you can replace your part with the new screen and digitizer assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Greg Cerabona
167 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Wilson Spring 2017 IUPUI, Team S2-G2, Wilson Spring 2017 üyesi
IUPUI-WILSON-S17S2G2
5 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 24
Her zaman: 1,015
