Giriş
The sub PCBA on the BLU studio 5.5 holds the charging port and connects to both the speaker and motherboard assembly so it holds a major role in many functionalities that you seek in your mobile device. This guide will demonstrate step by step how to remove and replace this crucial component.
Neye ihtiyacın var
Locate the notch to remove the back panel at the lower left corner of the panel.
Insert the plastic opening tool or a fingernail into the notch.
Apply force upwards until back panel becomes loosened.
Locate all twelve screws along the back panel:
Seven 5mm screws.
Five 3.5mm screws.
Using a Phillips #000 screwdriver, remove all twelve screws.
Now that all the screws have been removed, use a plastic opening tool to carefully pry at each of the corners until loosened.
Place the plastic opening tool inside the loosened panel and gently push upwards and move along the phone to remove the back panel.
Remove the panel as if you were turning the page of a book.
Locate the screw holding down the sub PCBA.
Remove the screw using the Phillips #000 screwdriver.
