Ana içeriğe geç
Blu Studio HD 6.0 MicroSD Card Replacement
Neye ihtiyacın var
  1. Blu Studio HD 6.0 MicroSD Card Replacement, Rear Case: adım 1, 1 resimden 1.
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 MicroSD Card Replacement, Back Panel.: adım 2, 2 resimden 1. Blu Studio HD 6.0 MicroSD Card Replacement, Back Panel.: adım 2, 2 resimden 2.
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 MicroSD Card Replacement: adım 3, 2 resimden 1. Blu Studio HD 6.0 MicroSD Card Replacement: adım 3, 2 resimden 2.
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 MicroSD Card Replacement, Insert the Micro-SD Card: adım 4, 3 resimden 1. Blu Studio HD 6.0 MicroSD Card Replacement, Insert the Micro-SD Card: adım 4, 3 resimden 2. Blu Studio HD 6.0 MicroSD Card Replacement, Insert the Micro-SD Card: adım 4, 3 resimden 3.
    • Find the Micro-SD card slot which is under the right SIM card slot.
    • Line up the gold pins of the Micro-SD card with the pins of the card slot. If pins in the slot are hidden, then insert the Micro-SD card with the "MicroSD" print up and the pins facing the slot.
    • Slide the card into the slot until you either hear a clicking noise or until the card does not move anymore. Do not apply too much force; gently slide it in and stop immediately when it does not move anymore.
  5. Blu Studio HD 6.0 MicroSD Card Replacement, Turn the phone on: adım 5, 1 resimden 1.
    • Your phone should boot up and ask you to format your Micro-SD Card.
    • Format the card and you're good to go.
    • If your phone does not recognize the card, ensure that the gold pins of the card aligned with the gold pins on the phone's Micro-SD slot.
    • If the card is installed correctly, the card may be faulty. If so contact the Micro-SD card manufacturer.
    My SD card was working just fine, then suddenly doesn't read. Attempted to remove and reinsert, but still doesn't read.
    Richard Cockrum - Yanıt
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Alec
617 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-1, Blackwell Fall 2014 USF Tampa, Team 9-1, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S9G1
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Very clear instructions and step by step guidance
Laszlo Tihanyi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 17
Her zaman: 16,309
